Hi a yellow triangle light in dashboard flashes? Also at one point it stayed on,what does this mean?
Feb 10, 2009 at 11:17 PM
GFIMOTORCARS
✓Experienced Mechanic
The yellow triangle means your traction control is slipping. It is a warning basically that you may be loosing traction. When the triangle stays on this could happen when the vehicle goes into a slide. Also if you turn off your ESP function the yellow triangle will come on and stay on in the dash until ESP is turned back on.
