1998 Mercedes Benz C230 check engine light
MSBELLA37
  • 1998 MERCEDES BENZ C230
  • 4 CYL
  • MANUAL
  • 85,000 MILES
My check engine light will not go off is there away to disconect it from a fuse? I have had all the test done on it. The shop thinks it is just my gas cap that I needed to replace. Which I have done.
Tuesday, October 14th, 2008 AT 10:57 AM
AUTOEVOLUTION
  • 14 POSTS
There isnt a fuse that will just make the check eng light go out. I understand a shop told you to replace the gas cap and that did not work. There is obvouisly a problem somewhere else. A shop would have to do more testing to see what failed; e.I : purge valve, leaky line, bad canister shutoff valve, etc. Another component is at fault if you still have the check engine light on. I would recommend to just ignore the light if your not going to fix the problem.
Monday, October 27th, 2008 AT 8:12 AM
