1998 Mercedes Benz C230
CHUCK55
  • 1998 MERCEDES BENZ C230
  • 4 CYL
  • 230,000 MILES
What happens when your car stops while driving/ i've changed the fuel pump and it still does not start
Thursday, June 10th, 2010 AT 10:53 AM
Lets do below for a start to determine if its fuel or spark related issue and get back asap.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Friday, June 11th, 2010 AT 4:23 AM
