1987 Mercedes Benz 560sel PLEASE HELP!
1987 MERCEDES BENZ 560SEL
SUBLIMEJUNKIE24
Engine Mechanical problem
1987 Mercedes Benz 560sel V8 Two Wheel Drive Automatic
When I started it, it will idle. but if you give it gas it dies, if your press on the the silver senter peice so it can breath it dies, when you start it black smoke comes out. how do you lean the gas/air mixture? pump and fuel filter is fine.
May 8, 2009 at 12:32 PM
DR LOOT
  • 2,311 POSTS
that vehicle is not adjustable you cannot adjust the air mixture, what you're experiencing is either a plugged fuel filter, or the fuel pumps(2) are bad, what's in your wallet? I hope lots of cash
May 18, 2009 at 12:58 PM
