1990 Mercedes Benz 300e muffler
1990 MERCEDES BENZ 300E
TVEYE52
Engine Mechanical problem
1990 Mercedes Benz 300e 6 cyl Two Wheel Drive Automatic 158.25 miles
The rear muffler broke loose from one of the suspension points and torqued, breaking off the exhaust pipe on inlet side. I need a new muffler and my mechanic's price for the part (from his supplier) is $480.
Searching on the web, I see ANSA mufflers for my model at a more reasonable $158. Are these OK to use? They claim back pressure etc. are the same.
Jul 4, 2009 at 5:34 AM
2CARPRO JACK
  • 11,533 POSTS
If it is an OE replacement, then Im sure it will perform just as good as the original.M/B doesnt actually make mufflers, the one you have now may even be an Ansa, you never know
Jul 10, 2009 at 2:28 AM
DR LOOT
  • 2,311 POSTS
This time have your mechanic drill a small hole in the rear of the muffler, so the condensation can drain out and not rust your exhaust again.
Nov 28, 2009 at 2:02 AM
