If the pedal was good b4 u started, it's airbound and you need to bleed the calipers of all air! Open the bleeders and let fluid drip out for a minute, don't run out of fluid in the Master cylinder. After you get fluid out of the bleederclose it then pump up the brake pedal. Let me know how you make out. The other thing to check is as you look at the bleeders they are on top? If not you have them mounted on the wrong sides!
SPONSORED LINKS
Thursday, August 16th, 2007 AT 4:50 PM
