1990 Mazda B2200 Block Heater Install
SHINKLY
1990 Mazda B2200 4Cyl 2.2L? - I need to install a block heater as my truck is now located in the
great white north. Does anyone know the best kind to get and how to install it. I am told by Napa it is not complicated as long as you can get access to the part of the block that has the circular plug where the heater goes. The heater I looked at is simply a single element in a U shape the screws into the block and has a rubber gasket that must be well lubricated prior to installation. I've taken a quick peek and am confused as to the location of where the heater would be installed. Any Advice? Thanks In Advance.
Sep 14, 2007 at 9:55 AM
  • 75,988 POSTS
[quote:7ee52a07d2="shinkly"]1990 Mazda B2200 4Cyl 2.2L? - I need to install a block heater as my truck is now located in the
great white north. Does anyone know the best kind to get and how to install it. I am told by Napa it is not complicated as long as you can get access to the part of the block that has the circular plug where the heater goes. The heater I looked at is simply a single element in a U shape the screws into the block and has a rubber gasket that must be well lubricated prior to installation. I've taken a quick peek and am confused as to the location of where the heater would be installed. Any Advice? Thanks In Advance.[/quote:7ee52a07d2]
You can use the in-line type that goes on the heater hose or the one you have- remove a freeze plug from the block the circular looking one -pop it out and install it correctly.
Sep 18, 2007 at 11:27 AM
Suggested Repair
Use either an inline heater installed in a heater hose or the freeze-plug style element. For the freeze-plug type, remove the circular freeze plug from the block, pop it out, and install the heater correctly with the gasket properly prepared.
Conversation Summary
The owner of a 1990 Mazda B2200 wants a block heater for cold weather and cannot locate the circular plug where a U-shaped element would install. The expert says an inline heater on a heater hose is an option, or the freeze-plug heater can be installed after removing the circular freeze plug from the block.
