1991 Mazda B2200 Idle Switch Adjustment Fix
ARMADOUR1
i have a 1991 mazda b2200 m/t carbureted. how do you adjust the idle switch at the front of the carb? thanks. armadour1
Aug 28, 2007 at 4:02 AM
2CARPRO JACK
  • 11,533 POSTS
Increase RPM'S to over 2,000. Gradually decreses RPM'S, at 1,00- 1200 RPM'S the voltage reading should be less than 1.5 volts and at idle it should be 12 volts.If not 12 at idle turn adjustment screw to achieve the proper reading
Aug 28, 2007 at 5:43 AM
Suggested Repair
Raise engine speed above 2,000 RPM, then gradually decrease it. Voltage should be less than 1.5 volts at 1,000-1,200 RPM and 12 volts at idle. If idle voltage is not 12 volts, turn the adjustment screw until the reading is correct.
Conversation Summary
The owner of a 1991 Mazda B2200 manual, carbureted truck asked how to adjust the idle switch at the front of the carburetor. The expert advised raising RPM above 2,000, then gradually reducing speed so voltage is under 1.5 volts around 1,000-1,200 RPM and 12 volts at idle, turning the adjustment screw if idle voltage is not 12 volts.
