2003 Mazda Truck Rebuild
2003 MAZDA TRUCK
69,500 MILES • 6 CYL • 2WD • AUTOMATIC
BLUETHUNDER216
How much should it cost to rebuild the transmission on a 03 Mazda Tribute 4X2 Automatic. The transmission wont pull in DRIVE but works fine in all other gears.
Jan 3, 2008 at 10:47 AM
  • 31,937 POSTS
Thank you for your donation.
With automatic transmissions, it is impossible to quote or even estimate on the probable cost of a re build, Transmission specialist wont do a quote or estimate over the counter either, you will be able to get a re-co fitted with a fixed quote, but because there are so many variable s involved, there is just no way you can quote with out dismantling and inspecting first.
mark (mhpautos)
Jan 3, 2008 at 1:03 PM
