2001 Mazda Truck
2001 MAZDA TRUCK
117,000 MILES • 6 CYL • 2WD • AUTOMATIC
BEEBSALOT
When I turned my truck on, it started but made a screeching sound. After it was on and making the screeching sound, it then made a POP sound and the truck turned off by itself. I tried turning it on, but it won't start. All the lights turn on, but it won't start. Any idea what's going on and how much it might be to fix?
Jun 16, 2008 at 2:56 PM
  • 31,937 POSTS
Hi there,
A screech may be a belt slipping because of a seized bearing, as for the pop... well i have no idea... will it crank over? if not check the starter, if it will crank, you will have to check for fuel delivery 7 spark. also do a scan to see if any set fault codes are present.
mark (mhpautos)
Jun 17, 2008 at 12:06 AM
