1992 Mazda Truck no spark
208,000 MILES • 4 CYL • 4WD • MANUAL
RUSS65034
I recently bought a 92 b2600i. The guy I bought it from said the ecm was bad,sent it to florida,checked out fine. I have power to the coil and thats it. There is a connection on the distributor with four wires,dont know what it's called but I unplugged it. Should I have power to any of the leads on the female end with the key turned on? Also I've seen a few questions where people said there computer was on the passenger side just forward of the door. What I sent in was under drivers seat. Was wondering if I sent wrong comp in.Thanks any help would be appreciated
Oct 28, 2008 at 5:07 PM
  • 75,988 POSTS
Verify these colors on the distributor
Pink/black/yellow and blue/black and yellow-if its correct check for power at black and yellow and get back asap
Oct 28, 2008 at 5:33 PM
RUSS65034
My colors are black,black yellow,pink,yellowblue. Went ahead and checked black yellow,nothing
Oct 29, 2008 at 2:05 AM
  • 75,988 POSTS
Also check the black and yellow wire for power at the injectors harness-no power here -test out the main relay it powers the coil and injectors-
Oct 29, 2008 at 5:34 AM
