1990 Mazda Truck clutch slave cylinder
1990 MAZDA TRUCK
150 MILES • 4 CYL • 4WD • MANUAL
HAWKEYESTRAT
I need to change the clutch slave cylinder and do i have to drop the transfer case ,tranny ,or is it just on the outside,easy job or a big one thanks........
Feb 2, 2008 at 1:19 AM
MIKE H R
  • 3,094 POSTS
the clutch slave is on the outside of the transmission on the drivers side. When you change it make sure it is alligned up properly, then secured and then you will have to bleed it.
Feb 2, 2008 at 3:16 AM
