First thing to do is. Pop the hood. Pull the innermost fuse. It should be pink and 30a. Get back in and try turning it over for about 10 seconds. Put the fuse back and try startin her up. These cars are known for flooding, I learned that the hard way. If this is the problem it is so simple to fix. If the car starts, run it for 10 minutes or so letting it warm up completely. If you shut it off before it can warm up it will definately be flooded the next time you try. The solution is to not shut it off when cold. If that doesnt work there are many other things it could be but I would need more details to give you a good answer. But the flooding is most likely it
SPONSORED LINKS
Monday, September 8th, 2008 AT 5:42 PM
