HOW DOES THE COMPUTER OPERATE THE TRANSMISSION
MAZDA PROTEGE
GILBERT123
I have a 1998 Mazda Protege 1.8 engine ,138,000 miles, automatic transmission. I recently had transmission problems-the mechanic replaced it with another transmission. Since then, the transmission does not change gears automatically in Dirve--you must manually change gears. The mechanic says that the computer does not control the transmission as it should--changed the computer--no luck. I spoke to another mechanic , he said that the computer must be programmed to operate the transmission. The original mechanic insists that the transmission he installed is good. I would appreciate any information on this.
Gilbert123
Sep 28, 2007 at 1:25 PM
We cant hear the fuel pump turn on: Does this mean cannot or you can.
If you cannot hear it,could be a voltage drop , the fuel pump relay or PCM
If you can hear it,check the fuel pressure,pressure ok.Check the injectors for pulse by listening for the clicking sound.
I have replaced the fuel pump cut out switch-meaning the inertia switch does it have power to it. It has to make it out of there to the pump
Jul 15, 2007 at 1:06 AM
