1994 Mazda Protege Clutch Pedal Stays Down
CABOOSETTE
I had a company check my brakes pads/rotors and after their outrageous price, I told them to put it back together. Now my clutch (goes to floor)won't come back up unless pulled up. What could be the problem? The brake pads and rotors do need changing, will do myself.
Thank you
94 Mazda Protege
89,000.00 actual miles
dual cam engine
standard transmission
Oct 8, 2007 at 10:29 AM
MERLIN2021
  • 17,250 POSTS
If it's a wet clutch, see if there is any air in the slave...
Oct 8, 2007 at 10:52 AM
COSMO
  • 347 POSTS
Well for one...the slave cylinders are common failures on those cars....but first try removing the brake fluid cap and pumping the clutch...I have seen more than one bad cap cause funny things on the clutch side of the resevoir (the brakes share fluid with the clutch)
Oct 11, 2007 at 12:43 PM
Suggested Repair
Remove the brake fluid reservoir cap and pump the clutch, since the brakes and clutch share fluid and a bad cap can cause this. Also check the clutch slave cylinder for air and for failure, which is common on these cars.
Conversation Summary
On a 1994 Mazda Protege with a manual transmission, the clutch pedal goes to the floor and will not return unless pulled up after a shop inspected the brakes and reassembled them. The pads and rotors still need replacement. Experts advised checking for air in the clutch slave cylinder, noting slave cylinders commonly fail on these cars, and first removing the shared brake-fluid reservoir cap and pumping the clutch because a bad cap can affect the clutch side.
