1998 Mazda Protege Plug Wire Boot Stuck
FRYAN
i was giving the car a tune up the other day and the boots on my plug wires came off i tried to use a screw driver to get them out with no luck anyone know a trick?
Mar 7, 2007 at 6:49 AM
COSMO
  • 347 POSTS
I have 'pick tools' or Dental tools for such problems....
If your at home you might be ablew to make soemthing out of a coat hanger bent at a 90 degree angle and cut off very short
Cosmo...Mazda TEch
Mar 7, 2007 at 9:49 PM
Suggested Repair
Use pick tools or dental tools to pull the stuck spark plug wire boots from the block. At home, a coat hanger bent at a 90-degree angle and cut very short can serve as a short hook.
Conversation Summary
The owner of a 1998 Mazda Protege was doing a tune-up when the spark plug wire boots came off and stuck in the block. A screwdriver did not remove them. A Mazda technician suggested pick or dental tools, or a short coat hanger bent at 90 degrees.
