2003 Mazda Protege oil plug
154,000 MILES • 4 CYL • FWD • AUTOMATIC
HENRY5120
  • 7 POSTS
how do you loosen the oil drain plug ,is it clockwise or counter to loosen and where is the oil filter
Mar 22, 2009 at 9:27 AM
ZAGMAN
[quote:5807c01e0b="henry5120"]Engine Mechanical problem
2003 Mazda Protege 4 cyl Front Wheel Drive Automatic 154000 miles
how do you loosen the oil drain plug ,is it clockwise or counter to loosen and where is the oil filter[/quote:5807c01e0b]
If you are under the car then the filter should be on the right side (passenger side).. a bit up behind the oil pan. Its difficult to find it as Proteges have a very tiny filter. The oil pan should be on that side too. You may notice a similar pan on the driver's side. DONT drain that one. To open the nut, turn it counterclockwise.
Apr 14, 2009 at 2:44 PM
