2002 Mazda Protege O/D Light Flashing
AJDAVIS1871
For the past few weeks my parking brake light on the dashboard has been coming on, particularly after i had slammed on the brakes. Then today the car was not accelerating past about 40-50 mph while driving on the interstate, and the the O/D off light on the dashboard began flashing repeatedly and would not turn off.
Jan 13, 2007 at 8:06 AM
COSMO
  • 347 POSTS
SOunds like you have two probelms.
One. The brake fluid might be low (brake light)
Two. If the o/d light is flashing there is probably something wrong with the transmission
Neither one of these problems would cause the other
HAve it checked out and let us know how things go
Cosmo....Mazda TEch
Jan 13, 2007 at 9:51 AM
Suggested Repair
Check the brake fluid level for the parking brake light. Have the transmission diagnosed for the flashing O/D light and limited acceleration; the two issues are likely unrelated.
Conversation Summary
A 2002 Mazda Protege with 53,500 miles showed a parking brake light, especially after hard braking, then would not accelerate past about 40-50 mph while the O/D off light flashed. The expert said low brake fluid may explain the brake light and a transmission fault may explain the flashing O/D light, and that the problems are separate and should be checked.
