This is a strange problem. I have had constant rough idle troubles with this vehicle. I have cleaned out and tested the EGR, IAC, throttle body, etc... This has greatly improved idle, however it still idles rough under the following conditions:
Closed loop operation with the brake light switch closed. ie: If the engine is warm and I press the brakes, the idle drops from 700 to 200. If I press the brake pedal and unplug the brake light switch the idle returns to normal. (this seems to eliminate the possibility of a vacuum leak at the brake booster). If the engine is cold it idles normally. If I disconnect the brake light switch it idles normally when warm. Does my computer have a problem or need to be reprogrammed? Does the TPS require adjustment? Thank you!
Alex
Alex
Dec 29, 2008 at 1:19 AM
