1995 Mazda Protege Brake lights
130,000 MILES • 4 CYL • FWD • MANUAL
CHILLWELL
What could cause the 2 main brake lights to go out yet the third window brake light works? I have replaced the brake switch, but that was not the problem. Any suggestions would be greatly appreciated.
Sep 13, 2008 at 10:47 AM
MMPRINCE4000
  • 8,548 POSTS
Other than the bulbs, check the wires to the bulbs for 12V, If none, then they may be on a seperate fuse or the wiring to them (most likely a common ground) is open.
If you have 12V, then the bulbs or there may be a short in the housing. Inspect the housing for any burn marks.
Sep 13, 2008 at 11:04 AM
MERLIN2021
  • 17,250 POSTS
Check the multifunction switch...on the column. On most fords, it's a green wire problem at the switch, and oh yeah, Mazda is a ford..
Sep 13, 2008 at 11:26 AM
