1990 Mazda Protege no spark
PAULJR21
  • 1990 MAZDA PROTEGE
  • 4 CYL
  • MANUAL
  • 150,000 MILES
Well I have tried everything with my dad. We have changed the distributor. I have new spark plug wires and spark plugs. Have enough gas. Enough volts and ohms in the coil and to the distribtor. Fuses r fine. Have gas in the carb when pressed on the gas. When I turn the key all it does is just turn over and will not start. Has no spark anywhere
Tuesday, January 19th, 2010 AT 1:54 PM
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Wednesday, January 20th, 2010 AT 2:19 AM
