Check for any set fault codes, also check for coil voltage, you may need the assistance of a mechanic with a back probe LED test light as you should not use a conventional test light on EFI ignition systems. It is sounding like a water short, check the main EFI fuse & engine fuse as well.
Mark (mhpautos)
SPONSORED LINKS
Wednesday, January 2nd, 2008 AT 3:43 AM
