1991 Mazda Navajo Non-battery starting problem
85,000 MILES • 6 CYL • AWD • AUTOMATIC
KEVINJSCAHILL
I recently bought my friend's 91 Navajo and, as soon as I bought it, it started having problems not starting. Twice, it refused to start, but, when I came back to it later, it started without getting jumped. Now, it just will not start.
When I turn the key, there is an almost buzzing noise and then a pop.
I had a guy from advanced auto parts check the battery, and the battery is fine. I removed it and cleaned it just in case.
People have suggested to me that it is the starter or the connections.
From the little information I can provide, what seems like the best course of action? Should I just go buy a starter and attempt to put it in myself?
Please help. I cannot find a job until I have a working car. Thank you so much in advance.
Jun 10, 2009 at 8:31 AM
  • 75,988 POSTS
Is it cranking over and will not start or just won't crank at all/nothing.
Jun 10, 2009 at 8:48 AM
KEVINJSCAHILL
There is no "rr-rrr-rr" sound like an engine starting. It's a flat sort of buzz (maybe grinding?) sound.
Jun 10, 2009 at 9:39 AM
  • 75,988 POSTS
The way you describe it sounds like the overrunning clutch on the starter is slipping-Repalce the starter
Jun 10, 2009 at 9:41 AM
