1994 Mazda MX-3 Thrown Timing Belt
GEM
Love my 94 mazda mx3! It's the 16 valve, 1.6L 4 cylinder DOHC. Has 157K miles (not all mine) -I've only had it about a year....but I threw the timing belt! I really thought it was the distributor - but it wasn't.
Could someone PLEASE tell me the clearance? Does it have zero tolerance or is it going to be well again once I get a belt? I can't find it in the Chilton's and I can't find a Haynes.[img:cb0c152d14]http://www.2carpros.com/forum/automotive_pictures/58035_Me_100406_1.jpg[/img:cb0c152d14]
Feb 6, 2007 at 2:42 PM
COSMO
  • 347 POSTS
nothing to worry about.....it is NOT a zero-clearance motor. Things should be fine.
Cosmo....Mazda TEch
Feb 7, 2007 at 3:20 AM
GEM
You were right - not 0 clearance and the baby is all better. However, it also messed up distributor and alternator. It's running! I had a super mechanic that came out of retirement just for the challenge.
Feb 16, 2007 at 10:12 PM
Suggested Repair
The 1.6L DOHC is not a zero-clearance engine, so a thrown timing belt should not bend the valves. Replace the timing belt and any related damaged parts, such as the distributor and alternator, then verify the engine runs normally.
Conversation Summary
The owner of a 1994 Mazda MX-3 1.6L 16-valve DOHC asked whether the engine has zero valve clearance after the timing belt broke. A Mazda technician said it is not a zero-clearance motor and should be fine. The owner later confirmed the engine was not interference, the car ran after the belt was replaced, and the distributor and alternator had also been damaged.
