1994 Mazda MX-6 CV Axle Won't Separate
NICOPICO25
HI I AVE A MAZDA 1994 MX6 v6 MANUAL TRANSMISSION WITH 124K ON IT AND MY OUTER CV SHAFT ITS BROKEN I WANT TO REPLACE IT BUT I CAN'T TAKE IT OFF FROM THE OTHER HALF SHAFT ,THIS IS ON THE PASSENGER SIDE I'D TRIED HAMMERS ,PRY BARS AND EVERYTHING ELSE BUT ITS DOESN'T DISCONNECT I NEED SOME ADVISE PLEASE THANKS.
Nov 25, 2006 at 7:39 AM
BRUCE HUNT
  • 3,754 POSTS
Are you trying to pull it away from the transmission or are you trying to seperate a middle joint. Take the entire half axle off and gently insert a small prybar between the tranny and axle. There is a snap ring that needs to slip out of the tranny and sometimes they get fussy.
Nov 27, 2006 at 12:23 PM
Suggested Repair
Remove the entire half axle, then gently insert a small prybar between the transmission and axle so the snap ring can slip out of the transmission.
Conversation Summary
The owner of a 1994 Mazda MX-6 with a manual transmission cannot separate the passenger-side outer CV shaft from the inner half shaft despite using hammers and pry bars. The expert advises removing the entire half axle and using a small prybar between the transmission and axle to release the snap ring.
