1988 Mazda MX-6 Oil Burn Emissions
BNYFTR
My 1988 Manual Mazda MX-6 burns three quarts of oil every three thousand miles, but runs great? It failed all of the emissions tests at inspection though. Is there anything I can replace that will make it pass?
Jan 27, 2007 at 10:15 AM
COSMO
  • 347 POSTS
The piston rings and valve guides/seals maybe!!!
If its burning that much oil....there really is nothing other than some major engine work.
I guess you should check you PCV valve, but 3 quarts.....I'm not sure that even a completely clogged PCV system could do that
Cosmo...Mazda TEch
Jan 27, 2007 at 11:09 AM
Suggested Repair
Check the PCV valve, but three quarts of oil every 3,000 miles is unlikely to be fixed by that alone. Expect major engine work such as piston rings and valve guides or seals.
Conversation Summary
A 1988 Mazda MX-6 burns about three quarts of oil every 3,000 miles, runs well otherwise, and failed emissions inspection. The owner asked whether a simple replacement could make it pass. The expert said piston rings and valve guides or seals are the likely cause and that major engine work is probably required, while also suggesting a PCV valve check even though a clogged PCV system alone is unlikely to explain that much oil use.
