1991 Mazda MX5 won't start
86,000 MILES • 4 CYL • 2WD • MANUAL
RAYCHITS
I have plenty of spark! When I jump fuel pump up front with jumper wire you can hear pump running! I replaced ECU new fuel pump and new fuel pump relay! Still won't start plenty of spark! I cleaned all ground contacts that I can find still won't start! I also replaced MAS still won't start! I have replaced the four injectors! I check all fuses that are good! When I try to start without jumper wire no fuel pressure! When I jump fuel pump with jumper wire engine will run as long as I spray gas into throttle body! What am I missing!
Dec 25, 2007 at 2:55 AM
  • 75,988 POSTS
Check for an injector/s pulse. You got spark and fuel pressure-when injector/s are not opening it will not give fuel to the combustion chamber. The new fuel pump did you check its pressure-could be new but defective not pushing the correct pressure.
Dec 25, 2007 at 5:03 AM
