1997 Mazda MX3 car problems
KELLYT1023
Engine Performance problem
1997 Mazda MX3 4 cyl Front Wheel Drive Automatic
My car was driving down the road and just shut off..it has power and it also turns over but the car wont start up. I checked oil and it was empty so I was wondering if there was a reset switch on my model of car if so where? or if you think you know what the problem is I am open to any suggestions
Dec 20, 2009 at 4:28 PM
  • 75,988 POSTS
Your don't have the fuel cut off switch-Do below to determine if its fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregar
Dec 20, 2009 at 5:42 PM
