2001 Mazda MPV temperture gauge
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
MUSCO
After replaceing the water pump and belt the temperature gauge stoped working. What caused this ?
Is there a senser somewhere or a fuse. what should i look for ?
Sep 21, 2010 at 5:23 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
I would be thinking that the temp sender wire has been knocked off, i will have to look at a manual to identify the exact location for you, but they are normally in the head at the front of the engine near the thermostat, i will see if i can find i pic to post.
mark (mhpautos)
Sep 21, 2010 at 7:12 PM
  • 31,937 POSTS
Hi there,
It's actually located at the rear of the cylinder head, the pic is not all that clear but it's all i have just now, as it is remote from where the work was done, i would also be checking that all the air has been bleed from the cooling system, the sender will only work if submerged in coolant.
mark (mhpautos)
Sep 21, 2010 at 7:19 PM
