1993 Mazda Miata Airbag Light Code
TOMP
93 Miata 78k miles 1800 - Airbag light flashes 10 times indicating control module (fuse). No specific issue to cause problem. Both under dash and engine compartment fuses good. Where is control module? What other things to check?
Mar 7, 2007 at 10:36 AM
2CARPRO JACK
  • 11,533 POSTS
Try the Repair Manuals link at the bottom of the main forum page. All the info and diagnostic help you need will be in there
Mar 7, 2007 at 11:52 PM
COSMO
  • 347 POSTS
The SRS control Module fuse is internal. You will need to replace the module if the fuse is faulty.
If memory serves me correct....you will have to remove the dash to replace the unit (but that might be the newer ones)
Cosmo...Mazda TEch
Mar 8, 2007 at 8:57 AM
Suggested Repair
The SRS control module fuse is internal. If that fuse is faulty, replace the SRS control module. Consult the repair manual for the module location, diagnostics, and whether dash removal is required.
Conversation Summary
The owner of a 1993 Mazda Miata reports the airbag light flashing 10 times, indicating a control-module fuse issue, although the under-dash and engine-compartment fuses test good. Experts say the SRS module fuse is internal and the module must be replaced if it is faulty, and recommend the repair manual for location and diagnostic steps. Dash removal may be required depending on the model year.
