Hi ,
I have Mazda pickup truck , manual 5 speed , 84,000 miles , I have a problem with my truck parked afew days and when I started engine the Gage check light is On and the pressure gage is sometime moved little bit or no pressure at on . I checked the oil in engine is full , I had to shut off and started on several time before check gage light off and oil pressure gage is normal .
The oil pressuresending unit is at passinger side on rear engine and it is very hard to pull the plug wire and remove oil pressure sending unit also ,
Is some one know How to remove oil pressure sending unit on Mazda b3000 , or have diagram of it ,to see how does it look like . I need to hook up oil pressure gage on the port to see how many pressure psi on engine oil pump.
If I started engine every 12h a time . Engine was fine every thing is ok no gage check light , oil pressure is normal ,
Any helps is aprecitiated .
Sep 27, 2009 at 4:25 PM
