1999 Mazda b3000 truck will not start after checking fuses?
213,000 MILES • 6 CYL • 4WD • AUTOMATIC
PAW75
Truck running good,checked all fuses now it will not start? Can jumper silnoide runs good but will not start
Aug 22, 2010 at 1:53 PM
  • 75,988 POSTS
If its cranking over will not start do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Aug 22, 2010 at 5:00 PM
