1994 Mazda b3000 O2 sensors
175,000 MILES • 6 CYL • 4WD • MANUAL
TURBOACC
I recently bought this truck and failed a state emissions test. I replaced the spark plugs, wires, cap and rotor, did an oil change, and bought O2 sensors. The salesman at NAPA told me this truck has 2, but I can only find the O2 sensor on the exhaust manifold by the transmission. Is there another, and if so, where is it? Is there anything else I should do to pass emissions?
Aug 31, 2009 at 2:26 PM
MERLIN2021
  • 17,250 POSTS
There is always 02 sensor(s) B4 the cat, and one after the cat, check for a connector there that's not connected, see if there is a steel plug screwed into the cat or the pipe right behind it, someone may have removed it.
Aug 31, 2009 at 7:40 PM
