1990 Mazda B2600 WON'T START WHEN HOT
BEACH2916
  • 1990 MAZDA B2600
  • 4 CYL
  • MANUAL
  • 90,000 MILES
TRUCK RUNS GREAT AND STARTS EVERY TIME WHEN COLD. WHEN HOT AND IT'S SHUT OFF IT WON'T START TILL IT SITS (AND I GUESS IT COOLS OFF). DOESN'T DO IT ALL THE TIME THOUGH. HELP!
Thursday, May 20th, 2010 AT 3:33 PM
Hi BEACH2916, Welcome to 2carpros and TY for the donation
Next time it refuses to start when its hot -Do below to determine if its a fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Thursday, May 20th, 2010 AT 4:20 PM
