1990 Mazda B2600
TORO2
  • 1990 MAZDA B2600
Electrical problem
1990 Mazda b2600 4 cyl Four Wheel Drive Manual 70k miles
I had posted a question regarding not being able to start a recently installed motor, you answered me to check starter motor ground, I checked all grounds, and cleaned all connections.I have also checked the clutch interlock, I can manually jump the starter, but it will not start with the key, any more sugestions? Thanks, toro2
Monday, October 18th, 2010 AT 5:17 PM
Hi Toro2, Welcome to 2carpros and TY for the donation
If you're talking about the only time it can crank the engine over is to go thru the starter motor -Did you check for power while in cranking postion on the black and yellow wire on the clutch switch if not check it no power means the ignition switch is decective or the wire is open to the switch.
Tuesday, October 19th, 2010 AT 3:36 PM
