2002 Mazda b2300 Clutch Slave Cylinder
66,000 MILES • 4 CYL • 2WD • MANUAL
MARKHAMS
My clutch suddenly went out the other morning and I had it towed to a local shop. They were able to diagnose the problem and fixed it for my, so I am back on the road which is great.
However, my clutch pedal now doesn't engage the clutch until it is almost all the way to the floor. It makes it somewhat tricky to drive, or maybe I am just not used to it, but it doesn't seem right.
Is this a problem? I mentioned it to the shop and they said different slave cylinders can be callibrated differnently, so I should be OK. But I am still worried about it.
Is this something that should be fixed? If so, what should be done to fix it?
Thanks,
Sam Markham
Jan 15, 2010 at 12:21 AM
BLUELIGHTNIN6
  • 16,542 POSTS
all clutches are different. some release at the very top while others release near the floorboard. it is tricky to get used to a new clutch "feel" if you are used to just the opposite of how it was doing.
Jan 15, 2010 at 8:00 AM
