1990 Mazda b2200 ignition switch problems
1990 MAZDA B2200
220,000 MILES • 4 CYL • 2WD • MANUAL
SWIFTBN
I need to know what to do if I have replaced the alternator and the starter, yet my truck doesnt start. when it does start, it starts smoothly. How do I take off the steering wheel and How do I replace the ignition switch or if I need to add on a strter button, for I have recently purchased a 60 amp push button, how would I install it?
Apr 24, 2010 at 9:24 AM
Inspect and test the clutch switch
Apr 24, 2010 at 3:37 PM
SWIFTBN
i already have a clutch that is good. this was installed brand new 5 years ago.
Apr 25, 2010 at 10:23 AM
I'm talking about the clutch switch that you have to step on the clutch pedal to close the circuit in order for the engine to crank over-
Apr 25, 2010 at 12:10 PM
SWIFTBN
oh no...that part is ok...it contacts well. all is well with the clutch pedal/switch. it is when i turn the toggle and attempt to crank the engine. when i did this on yesterday, i had to first get a jump for the batteries were dead. once getting the boost was successful, the truck started like it should when one replaces the old starter with the new, however, when i had the engine running i wanted to try something which led me to believe that i also am going to need a new battery. i turned on everything associated with the electrical; such as all the lights, the radio, windshield wipers, etc., and when i did that the charge light appeared which led me to turn everything off before killing the engine. finally, after killing the engine, the truck never turned over, although all the dash lights worked. even after i attempted the jump start again, i still struggled with the crank. this has to be the ignition switch because it is draining my batteries. would the 60 amp push button work just to start it until i can afford the new switch?
Apr 25, 2010 at 12:55 PM
