What are the steps to replacing the water pump?
What tools will I need to do this?
Thanks,
Adu
Drain the coolant, remove any hoses and fan attached to the pump, release belt tension, and remove the water pump bolts while noting their lengths. On this V6 the pump is behind the timing belt, so the timing belt must be removed and the tensioner checked for looseness. Clean the gasket surface, confirm the new pump matches the old one, and reassemble in reverse. Typical shop time is 4-5 hours; tools include 10, 12, 14, 19, and 21 mm wrenches and sockets, extensions, and a 1/2-inch impact gun. A professional is recommended if you are not experienced with timing-belt work.
The owner of a 1995 Mazda 626 V6 with 135,000 miles asked for water pump replacement steps and required tools. One reply gave general steps: drain coolant, remove attached hoses and fan, release the belt, unbolt and remove the pump, clean gasket material, compare the new pump, and reassemble. A Mazda technician added that the V6 pump is behind the timing belt, so the belt must come off and the tensioner should be checked for looseness. The job needs metric wrenches and sockets, extensions, and an impact gun, takes about 4-5 hours, and is better left to a professional.
