2000 Mazda 626 Vibration in Drive
PALMTREE
2000 Mazda 626 4cyl, 2.0 ltr, 133,000 miles
I recently had to use on of those tire donuts when a front tire went flat. I drove about 30 miles to a service station.
After the tire was replaced, I noticed a rough vibration when in "drive" while stopped at a light. Shifting to neutral stopped the vibration.
Two weeks later, yes I know I should have taken it in right away, it is vibrating in all gears but moreso in drive and reverse, when stopped. It seems to run fine when the car is moving more than 5 miles an hour.
Any ideas?
Aug 19, 2007 at 3:42 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds unrelated to the tire.Is the check engine light on? Has the car been tuned up? could be a miss and it is more noticable when the engine is under load (in gear). Could also be a motor mount that is collapsed or weak
Aug 20, 2007 at 12:51 AM
Suggested Repair
Treat the vibration as likely unrelated to the spare tire. Check for a check engine light and a misfire or needed tune-up, which is more noticeable under load in gear, and inspect the motor mounts for collapse or weakness.
Conversation Summary
A 2000 Mazda 626 began vibrating in Drive while stopped after about 30 miles on a spare donut; shifting to Neutral stopped it. Two weeks later it vibrated in all gears when stopped, more in Drive and Reverse, but ran fine above about 5 mph. The expert said this is likely unrelated to the tire and suggested an engine miss under load or a weak or collapsed motor mount.
