1999 Mazda 626 driver side low-beam comes on intermittant
145,000 MILES • 4 CYL • FWD • AUTOMATIC
THUMBSMCGEE
High beam always works. Low-beam comes on and off, sometimes goes back on when I slap the front of the headlamp. Nothing looks loose. Sometimes I notice a burning rubber smell from under the hood. Is this maybe connected?
Feb 20, 2009 at 11:45 AM
ZACKMAN
  • 4,202 POSTS
If you slap the headlight, and it comes back on, then something is definitely loose. Try removing the wire harness from the bulb to see if the harness is melting on the inside. That would explain the rubber smell.
Feb 22, 2009 at 8:25 PM
