have taken the vehicle in numerous Xs for the rear noise; each time the mechanic would shave the rotors, etc; now he's told me that the rear differentials are damaged -- please explain; :evil: :twisted: :(
Rear noise
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Ask for the documented hub and bearing findings and confirmation that the noise disappeared after repair.
Guidance references and applicability
Source: This question and its visible discussion. The roadmap distinguishes the original owner's reports from other participants' experiences; proposed follow-up is editorial guidance, not a confirmed diagnosis.
P.s. 626's and Mx-6's (almost the same cars) DO NOT have rears diffs. They are front wheel drive!
Cosmo..mazda tech
Discussion summary
Rear noise
The owner of a 1997 Mazda 626 reported persistent rear grinding noise after repeated visits involving rotor work. A later owner update attributed the rear noise to a worn rear hub and also reported worn front bearings.
Reported outcome: The owner identified hub and bearing wear but did not explicitly confirm completed replacement and a noise-free result.
A later exhaust-hanger suggestion was not a verified finding on this vehicle. The earlier report of rear-differential damage was not substantiated.
