1998 Mazda 626 Power Steering Failure
2. Was the pressure switch plugged in on the top of the power steering pump?
Cosmo...Mazda TEch
2. The only plug tip on the top was called the "PSP switch connector". If this is what you mean then yes, we plugged it in. We were wondering what that does, but did make sure it was plugged in.
Thanks for the ideas!
You might want to make sure that the wire going to this sensor is good and clean and has no rot to it.
Get that powersteering fluid completely out and re-fill the system
Cosmo...Mazda TEch
Thanks again for working with me on this!
Suggested Repair
Drain and thoroughly flush out the power steering fluid, then refill with the specified Dexron ATF. Confirm the power steering pressure switch is connected and that its wiring and connector are clean, tight, and free of damage or corrosion.
Conversation Summary
A 1998 Mazda 626 lost power steering after the pump bearing and seal failed. Replacement pumps still provided assist only intermittently or when the engine was revved, despite flushing, bleeding, and no visible leaks. A Mazda technician said the system requires ATF rather than power steering fluid and advised checking the pressure-switch connector and wiring, then flushing and refilling with ATF. After that was done, assist remained intermittent; the owner reused the original switch, noted a loose connector, and asked what the switch does, with no further expert reply.
