Mazda 626 stttuerring loss of power
CMURPHY
  • 1962 MAZDA 626
I have a 4.0cyl auto trans 1999 626 w/a rebuilt trans. Miles @ 100k. In the winter sir I noticed that when I turned the car on and turned don the heat the car wold make a squeal you could hear for miles. Then in the summer the AC doesnt work properly. If I leave it on @ 1 for 20 min it might kick on and blw cool air, but the car will loose power. When @ idle the cars engines shakes itself 30 sec or so every and the whole car vibrates. When I'm driving and the air kicks on the car will stutter and shimmy until I let off the gas. What is causing this problem is it the AC or O2 sensors air flow I'm in Afghanistan now but need to keep the car running for the family @ home please help!1
Soldiers on the line 4 America
Friday, October 12th, 2007 AT 10:54 AM
SNAKESMITH
I'm experiencing the same problem with the idle on my car with 125,000 miles on it. It's a 1998 626 as well. It drives fine on the highway, it just has this stutter at idle. Usually while it's in drive and the brake is engaged, not in park.
Any ideas?
Tuesday, November 6th, 2007 AT 12:15 PM
E-GIRL
Mine's a 1997 Mazda 626 miles are at about 180k, 4 cylinder and it does the same thing the car lot I bought it from says it's the 02 censor and my dad says the same thing also I took it to a transmission place and they also said to have the o2 censor replaced but I havent had the time or the money to do it but when I do i'll let you know what happens
Wednesday, November 14th, 2007 AT 3:17 PM
