1997 Mazda 626 Frozen Clutch
M93JSMITH2
I have a 1997 Mazda 626 4Cylinder with 145000 miles.
I had a lot of car problems, unrelated to my question, and a really slow mechanic. The car sat for about 5 months. When the repairs were done and I tried to start it. I found that I could not. The battery was dead and I replaced it. I could not get the car to start with the clutch pushed in. I thought that if the clutch was stuck in the engaged position, then it would try to start but the car would jump. If I get the car in motion, and in gear, and I stop it will stall. It will shift smoothly if the engine is off and the clutch is disengaged. I got it to start in neutral and with a push I drove it, shifting without the clutch. I replaced the slave cylinder and this did not help. The lever arm operates smootly when I push on it, with some resistance. The car will not go in gear, while sitting still, the motor running, and the clutch pedal pushed down. I don't want to rebuild the clutch if it does not need it, but I am not sure. Can you give advice?
May 27, 2006 at 6:01 AM
LOSONE
  • 1,616 POSTS
If every thing is working in the hydraulic system it is a frozen cluthc disc.
The old mechanics way of doing it is the get is rolling in first gear with the engine running snap the gas pedal several times with a good jerk and the clutch pedal pressed and then not pressed. it shoud free the clutch. Good luck
May 27, 2006 at 9:16 AM
Suggested Repair
If the clutch hydraulics are working, the disc is likely frozen from sitting. Try freeing it by rolling in first gear with the engine running and snapping the throttle several times while pressing and releasing the clutch pedal.
Conversation Summary
A 1997 Mazda 626 that sat for about five months would not start or shift with the clutch pedal depressed, and replacing the slave cylinder did not help. The expert said that if the hydraulic system is working, the clutch disc is frozen and may free by driving in first gear and snapping the throttle while working the clutch pedal.
