1993 Mazda 626 Warm Idle Surge
CARPOOLER
Hello
I have a 1993 Mazda 626Lx with 165,000 miles,it has the 2.0L engine and an automatic transmission,after the engine gets to operating temperature and you are at a stoplight,the engine will speed up and drop down,it will also try to cut out. Do you have any advice for this?
Sep 11, 2007 at 4:07 PM
  • 75,988 POSTS
[quote:4518360fef="carpooler"]Hello
I have a 1993 Mazda 626Lx with 165,000 miles,it has the 2.0L engine and an automatic transmission,after the engine gets to operating temperature and you are at a stoplight,the engine will speed up and drop down,it will also try to cut out. Do you have any advice for this?[/quote:4518360fef]
For a start check the idle control or speed device might need cleaning also investigate the EGR could be cracked open by carbon. and also the TPS.
Sep 11, 2007 at 7:30 PM
Suggested Repair
Clean the idle air control or idle speed control device. Inspect the EGR valve for carbon that may be holding it open, and check the throttle position sensor (TPS).
Conversation Summary
The owner of a 1993 Mazda 626 with 165,000 miles reports that after the 2.0L engine reaches operating temperature, idle speed rises and falls at stoplights and the engine tries to cut out. The expert recommends cleaning the idle control device, checking the EGR for carbon holding it open, and inspecting the TPS.
