1997 Mazda 626 P0421 Light
MWOODBURY
Year: 1997
Make: Mazda
Model: 626-LX Sedan
Engine: 4 Cylinder
Liter: 2.0 liter engine
Problem: Emission
Emission: Calif. Emission
Current Mileage: 124,450
I’ve read many columns of questions and answers of your website and spent a great deal of time reading and learning, but did not see this question and answer (the problem I’m describing below) on your website. HELP.....
Late Nov 2006, my car passed Safety (although emission did not). The auto shop kept coming up with a trouble code P0421 (this code causes orange malfunction check engine light to stay on dashboard), orange light looks like a battery symbol.
Shop informed me H02 Exhaust Oxygen Sensor may be the problem, they checked the old 02 exhaust oxygen sensor, showed me the part that looked worn and in bad condition. After some thinking, I agreed to have shop replace it ($227.25 for the part) tax, etc. = $268.89.
After the new 02 exhaust sensor was replaced. The shop told me to drive it (40 – 50 miles); believe P0421 should go off. Having driven to & from work of 96 miles in 3 days, took car back to shop, code P0421 came up once more, they asked me to drive it some more. I drove the car for few more days (to see if orange malfunction emission light may go off dashboard). It didn't.
Shop thought may be the H02 heat sensor may also be worn, checked the part, showed me the old part (most likely original part of the car that is 10 yrs old). I asked if I were to replace H02 heat sensor, would orange malfunction light stay off; they said it might although can't say for certain but worth a try. Based on my instinct and gut feelings, I thought they were honest of their opinions and gave me their findings (to let me decide to replace the 02 heat sensor or not).
They referred to their auto booklet which indicates the code P0421; showed me the page that it is “02 sensor problem”.
H02 heat sensor (was later installed, cost $200, add on tax, etc. = $240.00). Afterinstallation, orange malfunction light still came on (dashboard) when starting engine; shop's digital reader still came up P0421 code. Since they’re reset the computer, shop suggested I drive it some miles; orange malfunction light should go off.
Few days later, it seems that no matter how many times I've driven the car and put on mileage, orange malfunction light stayed on dashboard.
When this light stayed on, it does NOT effect the car, performance or whatsoever. It also does not cause any bad or poor air pollution that I noticed; I also did not detect any smoke, smog, or poor air pollution, no bad or unusual smell (even when I am behind the tail pipe). The air appears to runs CLEAN. I am beginning to feel the emission light (may be giving a faulty reading)??
My assumption is (computer inside the engine may be causing a faulty emission light to come on (?) I need help answering this question.
Since the orange light stayed on and no matter how many times the shop reset computer; the shop now thinks may be it is (UPPER GASKET OR UPPER MANIFOLD, may be the culprit). The upper Gasket while other shops call it "Upper Manifold") is located front of engine.
Shops such as MIDAS, MASTER MUFFLER, including the shop that replaced my (H02 Exhaust & H02 heat sensors) thinks the problem of P0421 remain on dashboard may be the (upper manifold) problem.
Question:
1. Since I didn’t detect any bad air pollution and my car is running in exceptional condition and very reliable; never breaks down. Easy to start in cold weather, reliable start in hot weather, excellent mileage. Based on the problem described, how do I know whether it is the (Upper Manifold) that is the problem? Or if the (CATALYTIC CONVERTER) that may be the problem?
Auto repairs are $$$, I need to rethink carefully before spending hard earnings. I don’t want the shop to tell me it is the (upper manifold) that needs replacement. They may be wrong (and later tells me it is the catalytic converter) that needs to be done.
Upper manifold from Master Muffler's for my car is quoted: $510 (part & labor), rear converter (which is the back one that is underneath the engine $180). I phoned another Master Muffler shop, they quoted me $650 upper manifold; rear converter $200.
MIDAS quoted me $865 (part) and $80 labor. Interestingly, when I called yet another MIDAS shop, quoted me a$320 (part & labor).
I called Mazda Dealer to check on (upper manifold) $330 and $80 labor. The parts dept educated me that very seldom, their shop has to replace rear converter, most commonly & almost all of the time, it is the (UPPER MANIFOLD) that costumers bring in their car for repairs of this problem. Rear converter is $1,156.
Please see if you can help answer my questions and provide me with some guidance, it would greatly help me sort out my budget and help me understand what I am dealing with. Thanks.
Dec 13, 2006 at 5:02 AM
BACKYARDMECHANIC
  • 337 POSTS
Sounds like you have a nightmare going on. I looked the code you and I didn't get O2 sensor but instead I got auxilary emmission controls. However I have no idea what it means. Sorry I could not be of more help. One other thing once the computer is reset does the light go off and come back on later.
Backyardmechanic
Dec 13, 2006 at 6:46 AM
MWOODBURY
[quote="backyardmechanic"] Sounds like you have a nightmare going on. I looked the code you and I didn't get O2 sensor but instead I got auxilary emmission controls. However I have no idea what it means. Sorry I could not be of more help. One other thing once the computer is reset does the light go off and come back on later.
Backyardmechanic[/quote]
Dear Backyardmechanic:
Once the shop reset computer in my car, orange malfunction battery symbol light goes OFF. Sometimes, stays off for a good 3-5 days and then orange light comes back on.
I've taken car back to shop, they reset computer once more, orange light goes off. I then drive some more; in few more days, orange light comes back on while I am driving. It is rentlentless. Do you think you can identify whether 1) upper manifold is the problem or (2) catalytic converter problem? Help.
Dec 13, 2006 at 6:59 AM
  • 75,988 POSTS
[quote:21b30ae3bd="mwoodbury"]Year: 1997
Make: Mazda
Model: 626-LX Sedan
Engine: 4 Cylinder
Problem: Emission
What's the IM240 readings
Question:
Please see if you can help answer my questions and provide me with some guidance, it would greatly help me sort out my budget and help me understand what I am dealing with. Thanks.[/quote:21b30ae3bd]
Dec 13, 2006 at 7:05 AM
MWOODBURY
Rasmataz:
I didn't see a written message from you. It is blank.
Thought I let you know.
[quote="rasmataz"][quote="mwoodbury"]Year: 1997
Make: Mazda
Model: 626-LX Sedan
Engine: 4 Cylinder
Problem: Emission
Question:
Please see if you can help answer my questions and provide me with some guidance, it would greatly help me sort out my budget and help me understand what I am dealing with. Thanks.[/quote][/quote]
Dec 13, 2006 at 7:28 AM
BACKYARDMECHANIC
  • 337 POSTS
[quote:db45c6922b="mwoodbury"][quote:db45c6922b="backyardmechanic"] Sounds like you have a nightmare going on. I looked the code you and I didn't get O2 sensor but instead I got auxilary emmission controls. However I have no idea what it means. Sorry I could not be of more help. One other thing once the computer is reset does the light go off and come back on later.
Backyardmechanic[/quote:db45c6922b]
I've taken car back to shop, they reset computer once more, orange light goes off. I then drive some more; in few more days, orange light comes back on while I am driving. It is rentlentless. Do you think you can identify whether 1) upper manifold is the problem or (2) catalytic converter problem? Help.[/quote:db45c6922b]
The only think I can think of is to remove the cat and replace it with a test pipe. If the light doesn't come back on then you can replace the cat. A test pipe is alot cheaper then a catalytic converter. I hate to change parts without really knowing if its bad. As far as the upper manifold being the problem I wouldn't know where to begin. Sorry
Dec 13, 2006 at 8:16 AM
  • 75,988 POSTS
[quote:43256eb8e7="mwoodbury"]Rasmataz:
[quote:43256eb8e7="rasmataz"][quote:43256eb8e7="mwoodbury"]Year: 1997
Make: Mazda
Model: 626-LX Sedan
Engine: 4 Cylinder
Problem: Emission
Question:
Please see if you can help answer my questions and provide me with some guidance, it would greatly help me sort out my budget and help me understand what I am dealing with. Thanks.[/quote:43256eb8e7][/quote:43256eb8e7][/quote:43256eb8e7]
You know why its blank because someone delete it.
Dec 13, 2006 at 8:12 PM
COSMO
  • 347 POSTS
It is more than likely the front cat (the one that is bolted to the manifold). There is an easy way to check if the cat is bad by monitroing the front and rear 02 sensors. There is also a PCM softwear update for this concern that may need to be done to help this from happening again
Cosmo...Mazda Tech
Dec 13, 2006 at 9:40 PM
Suggested Repair
P0421 is most likely the front catalytic converter bolted to the manifold, not the upper manifold. Compare front and rear oxygen-sensor readings to confirm converter efficiency before replacing parts, and check whether a PCM software update applies so the code does not return.
Conversation Summary
A 1997 Mazda 626 with California emissions failed inspection with code P0421 and a recurring warning light. Replacing the exhaust oxygen sensor and heated oxygen sensor did not help; the light returns a few days after each computer reset while the car otherwise runs normally. Shops suggested an upper manifold, but a Mazda technician said the front catalytic converter is the more likely cause and recommended monitoring the front and rear oxygen sensors, plus a possible PCM software update. Another reply suggested a temporary test pipe only as a cheaper way to see whether the converter is at fault.
