2001 Mazda 626 Tight driving
113,000 MILES • 4 CYL • FWD • AUTOMATIC
KRYSTAL RICHTER
I'll try to explain this, early morning seems to run just fine, I drive peroidocally all day off and on. By mid afternoon, car rpm's seem to be higher and take longer to shift into driving gear. Also brake becomes really tight. When I turn on the AC really seems to run high on the RPM's. I recently had a brake job and the fuel injectors flushed. Before the flush when sitting at a light the hood would shake, but know idles fine, but the driving exceleration seems to be sluggish/tight. Any suggestions??
May 12, 2010 at 11:16 AM
  • 31,937 POSTS
Hi there,
I would get the brake work done re inspected as i feel this is the root cause of you problem, it may be a residual pressure problem due to a faulty master cylinder or incorrect pedal free play, have this checked out first.
mark (mhpautos)
May 12, 2010 at 11:55 AM
