I cannot catch drive at a standstill.
138,000 MILES • 2.0L • 4 CYL • AUTOMATIC
ALWAYSAFK
Hi there, let me elaborate a bit for you.
This started on 8/15.
I crested a hill and put it into neutral and when I got to the bottom, I popped it back into the drive position but it wouldn't catch.
As of right now, I can shift into P, R, N, D2, and D1 no problem. Whenever I shift into drive at a stand still, it acts as if it is still in neutral. When I shift into D2 or D1, it will take a while to realize that I am in these gears before catching them. If I get my car into D2 and going about 35 mph or 3.5k rpms, I can shift it into drive and it attempts to catch third, if it catches third, I can get it to catch fourth by accelerating however it has to rev into very high rpms (4.5-5k) before it catches. If I am in drive and come to a stop, it shifts out of drive and feels like it is in neutral since I can roll backwards There are no warning lights on.
Aug 21, 2015 at 6:50 AM
ALWAYSAFK
Update*
After some monkeying around in the car, I discovered that my car can still engage drive only if my O/D OFF light is on. I haven't done any testing around this but what might be causing this sort of thing to happen?
Aug 21, 2015 at 7:44 AM
HMAC300
  • 48,601 POSTS
scan for codes first
Aug 21, 2015 at 11:08 PM
ALWAYSAFK
I actually did. I've got the codes p1250 and p0421. I was told that those don't relate to my problem though. I could be wrong though and I hope that it would be a simple fix.
Aug 23, 2015 at 4:03 AM
HMAC300
  • 48,601 POSTS
it may be a burnt clutch pak if your od light is on then that is a torque converter problem so a trans guy has to look at this.
Aug 23, 2015 at 4:11 AM
ALWAYSAFK
Okay. Thank you for your ideas and thoughts :). Any info is better than none.
Aug 23, 2015 at 5:46 AM
