2001 Mazda 626 - 4cyl
DANIELS1599
I am having problems starting my Mazda, it has 72,000 miles on it. After the car has been sitting for a bit it is very difficult to turn over. If it hasn't been sitting very long then it starts easily. Also when you are idling at a stop light it sounds like it may die. We've plugged it in and they said that the 3rd Cylinder wasn't firing. We've changed the air filter, fuel filter, spark plugs, and coil. Not sure what else to try.
Nov 10, 2007 at 6:10 AM
  • 75,988 POSTS
Try checking the fuel pressure with a gauge and comeback with the readings this will eliminate a fuel pressure problem.
Nov 10, 2007 at 8:37 AM
DANIELS1599
ok
Nov 13, 2007 at 2:36 AM
