2000 Mazda 626 P0420 Code
COASTIE JOHN
Greetings,
First time poster. I have a 2000 626 with about 64K miles, a 2.0 and auto trans. I have been working the P0420 problem with mine. I have changed out both the front and rear O2 sensors. Did the rear first. After about 3 weeks the light came back. Did the front, then light came back after 2 months. In the reading I have done, I have seen mentioned that the cat could be bad. I have also seen there is a TSB regarding the limits the PCM senses the tolerence level between the front and rear O2 sensor. This tolerence window is set too close together and sometimes sets off the code. You can take the car into the dealer and they expand the tolerence window within the PCM. I'm not sure if the TSB was for this year 626.
Does anyone have any other ideas for things to check?
Thanks.....John
Apr 7, 2007 at 2:32 PM
  • 75,988 POSTS
[quote:6cc906546b="Coastie John"]Greetings,
Thanks.....John[/quote:6cc906546b]
The sniffers are they OEM's try having it reflash
Apr 9, 2007 at 12:35 AM
MWHITNEY
  • 63 POSTS
yes the cat can be bad, abd yes the window in the pcm could be off. You need to get it too the dealer. cause they are the only one that can reflash pcm. And if the cat is bad any one can replace it but I not sure where this applies to but in NC the law 8 years or 80 k miles free replacement by factory.
Apr 9, 2007 at 1:53 AM
COASTIE JOHN
Thank you for the reply.......John
Apr 9, 2007 at 12:58 PM
Suggested Repair
Confirm the oxygen sensors are OEM, then have a dealer reflash the PCM to widen the O2 sensor tolerance window. If the P0420 code returns, inspect and replace the catalytic converter if it has failed.
Conversation Summary
The owner of a 2000 Mazda 626 with a 2.0L and automatic transmission has a recurring P0420 code after replacing both front and rear oxygen sensors. Replies suggest verifying OEM sensors, having the dealer reflash the PCM for the known tight tolerance window, and checking the catalytic converter, which anyone can replace.
